Update preprocess authored by Albanne Lecointre's avatar Albanne Lecointre
# 0.01-30.0 Hz
Code preprocess_refact.py, git revision **xxx**
- Get input, client RESIF, jday +/- 1 min
- No interpolation, assume that trace is already 200Hz and starts at `00:00:00.000000 +/- n * 1./200`
- Cut the trace(s) between 00:00:00.000000 and 23:59:59.995000
- Fill eventual gaps with zeroes
- Butterworth Bandpass Filter between 0.01 and 30.0 Hz, order 4
- write float32 h5 datasets, as :
> h5ls -rv FR.OGS1.00.HHZ.trace.float32.h5
Job monocore, pas activé MPI.
- OGS1 : job dahu 27039146 : xxh
- OGS3 : job dahu 27039150 : xxh
$ ls -lh /bettik/lecoinal/GEOBS/
# 0.01-30.0 Hz , 1-Bit
Code preprocess_refact.py, git revision a2a50b7b
......@@ -6,7 +36,7 @@ Code preprocess_refact.py, git revision a2a50b7b
- 1-bit filtering
- write h5 datasets, as :
- write integer h5 datasets, as :
> h5ls -rv FR.OGS1.00.HHZ.trace.int8.h5
